Krups ?
- Motorenspezi
Re: Krups ?
Hello Kjell,
I do not know the engine, is it a German engine? Where was the deployment, stationary or marine?
Best regards Mathias
Kjell
- Meine Motoren: Solo, Gray, Albin Meteor, Tune. Evinrude, Magne. Villiers and some unknown
Re: Krups ?
Hello and thank You for Your answer!
I have been searching for any information about my marine motor for a couple of years and no response anywhere. But last week a norwegian told me it was an german Krups. Found nothing on Google
- Motorenspezi
Re: Krups ?
Hello, your engine does not look like in Germany built, the water pump is not installed on German engines. Also the ignition magnet at the position is not usual. I will look at the weekend again, if I find something
Kjell
Re: Krups ?
Thank You!!
Re: Krups ?
Hello
I don't know a German engine manufacturer named "Krups". Do you know the brand of the carburettor? Maybe this will help us. The position of the magneto might be rather typical for a French engine.
Kjell
Re: Krups ?
The carb is a copy of a Schebler no name on it
Kjell
Re: Krups ?
There are some odd things on the engine
Overhead valves
Strange place for the magneto
Funny inlet
Cylinder and upper part of block in one piece
Overhead valves
Funny inlet
